Custom Reports with Repeats Issue
1469
02-01-2019 07:14 AM
SMW_GIS
Hi everyone.
I'm having an issue with formatting of answers from a repeated section of my form in a customized report.  I need to know if this functionality is possible.  If not then I need to explore other options.  Is there a way to split the answers from a repeated section of my form into multiple rows in a table? Please help! This is a big issue that is slowing down a deliverable that needs to be submitted.
My report has 3 sections of rows in a table that need to be populated with answers from 3 records in a repeated group. Right now it is grouping all answers in one row.  See my screen shots below. I've also attached a word document that may be easier to read.
My custom report is set up like this:
Pipe Num
Clk Pos
Pipe Dir
Pipe Material
Pipe Shape
Pipe Dia
Seal Condition
Special Condition
Access Point ID
${#Manhole_Connections} ${Pipe_Number} ${/Manhole_Connections}
${#Manhole_Connections} ${Clock_Position} ${/Manhole_Connections}
${#Manhole_Connections} ${Direction} ${/Manhole_Connections}
${#Manhole_Connections} ${Material} ${/Manhole_Connections}
${#Manhole_Connections} ${Shape}${/Manhole_Connections}
${#Manhole_Connections} ${Diam_1} ${/Manhole_Connections}
${#Manhole_Connections} ${Seal_Condition} ${/Manhole_Connections}
${#Manhole_Connections} ${Special_Condition}${/Manhole_Connections}
${#Manhole_Connections} ${Structure_ID} ${/Manhole_Connections}
Comments:
${#Manhole_Connections} ${Comments} ${/Manhole_Connections}
Comments:
Comments:
The report generates results that look like this:
Pipe Num
Clk Pos
Pipe Dir
Pipe Material
Pipe Shape
Pipe Dia
Seal Condition
Special Condition
Access Point ID
 1  2  3
 6  12  3
 OUT  IN  IN
 Vitrified Clay Pipe  Vitrified Clay Pipe  Vitrified Clay Pipe
 Circular Circular Circular
 8  8  8
 Sound  Sound  Sound
 Gravity Relief ConnectionGravity Relief ConnectionGravity Relief Connection
 21843MH_21855MH  21862MH_21843MH  31349MH_21843MH
Comments:
 1  2  3
 6  12  3
 OUT  IN  IN
 8  8  8
 Sound  Sound  Sound
Comments:
 1  2  3
 6  12  3
 OUT  IN  IN
 8  8  8
 Sound  Sound  Sound
Comments:
I'd like my report to generate results that look like this:
Pipe Num
Clk Pos
Pipe Dir
Pipe Material
Pipe Shape
Pipe Dia
Seal Condition
Special Condition
Access Point ID
 OUT
 Vitrified Clay Pipe
 Circular
 8
 Sound
 21843MH_21855MH
Comments:
 IN
 Vitrified Clay Pipe
 Circular
 8
 Sound
21862MH_21843MH
Comments:
 IN
Vitrified Clay Pipe
 Circular
 8
 Sound
 31349MH_21843MH
Comments:
Thank you for any help that you can offer.
Steven
JamesTedrick
Esri Esteemed Contributor
Hi Steven,
The repeat itself will handle the creation of the additional rows; I believe this format will accomplish what you are wanting:
JamesTedrick
Hi Steven,
SMW_GIS
Thank you James! That worked as you described. I needed to strip away the other rows and use the format you listed. The report generated new rows for the repeats in the same formatting.  Saved me so much time. Really appreciate it!
