Using select multiple choice question to generate next question?
1260
01-29-2019 01:40 PM
JimmyErnst
I have a list of about 125 plant species I want to use for a multiple choice question.  I want only the selected choices to appear in a much shorter list.  Those species would have spinners on them so the number of plants of each species could be counted and then calculations made on the numbers.
List of 125 species => select 10 => list of 10 species => count how many of each species are present using spinner on each one.
Any ideas on setting this up?
JakeSimms1
Jimmy great question. You would use the select function on the multiple choice question row, then modify the appearance value to spinner. This is outlined in the following GeoNet posts.
"Relevant" field syntax for multiple choice questions
https://community.esri.com/groups/survey123/blog/2016/05/28/the-art-of-hiding
https://community.esri.com/groups/survey123/blog/2017/08/30/understanding-multiple-choice-questions-...
Appearance—Survey123 for ArcGIS | ArcGIS
JimmyErnst1
Does this mean I will need 125 'selected' questions?
