Can't see drop-list of data in map viewer ??
883
01-28-2019 05:41 AM
RawandDizayee
Dear Esri team,
Please could you help me with this issue i really appreciate it,
When i publish my forms from survey123 connect to my portal i cant see drop-list of data,
to be more clear i give select_one{list} list of names when i publish it to portal in map viewer when i click on data table sometimes i can see drop-list sometime not shown it for the columns which i gave list of names. i attached image for demonstration.
thank you alot in advance
Jim-Moore
Hi Rawand
Could you please send your XLSForm so I can investigate further?
Have you republished your survey with changes to the lists on the choices tab? If so, the domain values on the feature service are not automatically updated when republishing, so this might explain why some values are not appearing.
Jim
RawandDizayee
Dear Jim,
Thank you a lot for your replay  fortunately i found the solution of the issue i mentioned.
