list APRXs in workspace folder
5939
01-23-2019 11:44 AM
JaredPilbeam2
I'm in the process of migrating my stand-alone python scripts from ArcMap to ArcGIS Pro. Using PyScripter as an IDE, I was able to successfully set up my environment. I'm using Python 3.6.2 that came with Pro 2.1.
I want to simply list the files in the workspace folder. Line 3 causes an OSError.
import arcpy, os
aprx = arcpy.mp.ArcGISProject(r"Path\to\folder")
#list the APRXs of the workspace folder
for root, dirs, files, in os.walk(aprx):
    for f in files:
        if f.endswith(".aprx"):
            mxd = arcpy.mp.ArcGISProject(os.path.join(root, f))
            print("current map being checked is  " + f)
How do I create a variable for the workspace folder for Pro? Here's how I would've done it for ArcMap:
ws = arcpy.env.workspace = r'path\to\folder'
DarrenWiens2
It looks like you should reference a aprx file, not directory. For example:
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\blank.aprx")
Also, os.walk doesn't specifically have anything to do with ArcGIS or arcpy. Pass it a plain old directory string. For example:
rootDir = '.'
for dirName, subdirList, fileList in os.walk(rootDir):
DanPatterson_Retired
that returns a project
from arcpy import mp as MAP
aprx = MAP.ArcGISProject('c:/Projects/YosemiteNP/Yosemite.aprx')
#or
aprx = mp.ArcGISProject('c:/Projects/YosemiteNP/Yosemite.aprx')
# ---- to start in that folder
"/".join(aprx.split("/")[:-1])
'c:/Projects/YosemiteNP'
JaredPilbeam2
Thanks for the help.
Apologies if I wasn't too clear. I wanted to list any and all projects (APRXs) in a folder. Sometimes spelling it out answers your own question.
It looks like you can use the same environment variable as you would with ArcPy in ArcMap. This worked:
ws = arcpy.env.workspace = r"path\to\folder"
Whole thing:
import arcpy, os
for root, dirs, files, in os.walk(ws):
    for f in files:
            print("current project being checked is  " + f)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
