Controlling z order of individual features in the same layer
1529
01-21-2019 05:15 PM
by Anonymous User
Not applicable
Does anyone know of a way to control the visual z order of individual features in the same layer?
e.g.
Say I draw two overlapping circles in the same feature layer. One is attributed with 'A' and the other as 'B'. I always want 'A' to display above 'B'. In fact, I want all circles attributed with 'A' to display above all the 'B' ones, no matter what order they got created/digitized.
The only way I can think at the moment is by adding the layer twice, with definition expressions, and thereby controlling which 'layer' is above the other. But does anyone know of a way to do it in the same layer using symbology of some sort?
cheers,
-Paul
LucasDanzinger
Esri Frequent Contributor
I don't believe there is a way at the moment. As a workaround for the time being, you could create a Graphic based on the symbol and geometry of the feature that you desire to "promote" and add a graphic to an overlay to give the illusion that the z index is changing
ErwinSoekianto
Esri Alum
Looping in ArcGIS Runtime SDK for Qt‌ to see if anyone know how to do this.
LucasDanzinger
BillFox
MVP Notable Contributor
Is this referring to a vertical coordinate system?
by Anonymous User
Not applicable
Hi Bill
No, the actual vertical elevation of a feature I think matters in a SceneView where features are actually rendered in 3D space, but here I'm just referring to a basic 2D MapView. So when I mentioned "Z value" I had in mind more what Luke meant re the "z value" of a Graphic which defines the stacking order of graphics on the screen.
Cheers,
-Paul
