How can I show the "loading animation" using ArcGIS Pro SDK (C#)?
2531
01-17-2019 07:59 AM
CarstenAndersson
Is it possible to show that loading animation  using the ArcGIS Pro SDK in C#?
I have create some custom controls, that perform some async calls like getting data from a service, and until the service has responded I want to show that little animation.
Is it possible?
Thanks in advance
Carsten
MaxMax2
There is a CircularAnimationControl in Pro SDK. Can you use it?
CharlesMacleod
Hi Max Max, yes you can. Add the control into your user control in the XAML. Bind its visibility to a property on your view model. Whenever you want to show the control, flip the property true or "Visible".
For an example look here:DockPaneBookmarkAdvanced - Bookmark.xaml   (There is also a WaitingCursorControl which acts identically but has a slightly different look is all)
