Multiple Line Datasets
756
01-15-2019 03:05 PM
JimCrane
I have two line feature classes: One shows new proposed fireline locations and the other, locations of roads/trails that may be used for firelines. These two line sets are concurrent in multiple locations. How do I Spatial Join, Intersect, etc. to produce one line set that shows the new construction and the existing (roads/trails) lines.?
AdamEversole1
Hi Jim,
One workflow is make a third feature to represent the intersection.
- layer 1 is Fierline
- layer 2 is Roads
- Use Intersect
- Result is Layer 3 Fireline - Roads
Or, A second workflow would be to Attribute one feature class with fact it is also the other feature class.
-Run Add field on the Fireline layer adding "IsRoad"
-Use Split by Line at vertices on the Fireline
-Select by location the fireline when it intersects the road (Tool or Workflow)
-Calculate field "IsRoad" = Yes  (This only attributes the selected records)
-Dissolve the Fireline on name and IsRoad fields
- Result is a field in Fireline identifying it is a road.
Hopefully one of these works, If not can you help me understand your data better? What's important about the intersection or final output.
Cheers,
- Adam
