input fails for no reason
3396
01-15-2019 02:04 PM
BrianLomas
We have a series of mqtt inputs which output into a series of feature services. We have an issue of some of the inputs randomly failing causing it to not produce an output. Basically, the input looks as though it is running (counting up) but no data is getting passed it. In order to solve the issue we just clone the input and it works. Therefore, we know it's not an issue with the GE service. So, somehow the input is getting corrupted or something. Has anyone run into this and solve it?
Geoevent 10.6.1
Windows Server 2012 R2
JamesMadden1
We are experiencing a similar issue with the send email output connector.  The service works for about a month and then stops.  The current resolution involves cloning the output and replacing the old one with the new one.  Not a long term solution for us since we need a reliable output that won't fail and need to be reconfigured.  I've read a lot of threads describing similar defects.  We are also running 10.61 with plans to migrate to 10.7 in the coming months.
