List Fields In Feature In Pro SDK
5306
5
01-14-2019 06:40 AM
MapVis
I am trying to get a list of the fields in a feature inside the project default geodatabase.
what is the c# pro sdk equivalent of the python below?
for lyr in m.listLayers():
            if lyr.name == "layer":
                field_names = []
                fields = arcpy.ListFields(lyr)
                for field in fields:
                    field_names.append(field.name)
Do i have to go through the geodatabse API with a feature definition to get that list? like below. or is there a shorter or more prefered way?
using (Geodatabase fileGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath((uri))))
using (FeatureClass featureClass = fileGeodatabase.OpenDataset<FeatureClass>(matchLyr))
   FeatureClassDefinition LyrDefinition = featureClass.GetDefinition();
   IReadOnlyList<Field> fields = LyrDefinition.GetFields();
   List<string> fieldList = new List<string>();
   foreach (var fld in fields)
      fieldList.Add(fld.Name);
      Debug.WriteLine(fld.Name);
   return fieldList;
RichRuh
I was confused by this at first too.  The statement
return matchField
exits the delegate passed to QueuedTask.Run().  You still have to return a value from the GetFieldList() function.
You *could* say
return await ArcGIS.Desktop.Framework.ThreadingTasks.QueuedTask.Run(...
However my colleague Charles Macleod‌ recommended the following:
public static async Task<string> GetFieldList(…
return await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
And then await GetFieldList() in the calling function.
RichRuh
You can actually call Geodatabase.GetDefinition<FeatureClassDefinition>() to go directly from the file geodatabase to the definition without incurring the overhead of opening the table.  Other than that, this code is the correct way to get the field list.
--Rich
MapVis
Thanks Rich it seems to be working but im getting an error "not all code paths return a value". Im confused if it runs the task,  gets the table definition, gets the field list, adds the field name to a list, intersects 2 lists to get the first matching value, then returns the matching value, what other code path would there be?
public static async Task<string> GetFieldList(string layer, string projGDBPath, List<string> fieldOneOptions)
        using (Geodatabase fileGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(projGDBPath))))
        using (FeatureClassDefinition featureClass = fileGeodatabase.GetDefinition<FeatureClassDefinition>(layer))
             IReadOnlyList<Field> fields = featureClass.GetFields();
       string matchField = fieldOneOptions.Intersect(fieldList).FirstOrDefault().ToString();
       return matchField;
RichRuh
return matchField
You *could* say
MapVis
awaiting GetFieldList() from Charles worked great. Thanks.
NarelleChedzey
If you already have the layer you can also do something similar to the following
IReadOnlyList<ArcGIS.Core.Data.Field> fields = null;
await QueuedTask.Run(() =>
   ArcGIS.Core.Data.Table table = theFeatureLayer.GetTable();
   if (table != null)
      ArcGIS.Core.Data.TableDefinition def = table.GetDefinition();
      fields = def.GetFields();
You still end up looking at the feature layer / table definition, but because you have the layer you don't need the additional Geodatabase object.
