Maintain DWG styling using Data Interoperability
1863
01-14-2019 08:37 AM
BenSmith6
I am attempting to Convert a DWG to a geodatabase for online publishing and use in collector. The conversion itself is fine, however I am also attempting to maintain style, i.e. annotation, colour, etc.
I have exposed autocad_color but obviously this is a numeric value, rather than RGB or something ArcGIS Pro can work with. I have also attempted to expose fme_color but that will not appear as an attribute. What am I missing?
BenSmith6
@StephenSontag3just noticed your kudos here and thought I might be able to help a little.
CAD colour codes do translate to RGB, but I've not found a quick way of doing it. The best I've found is:
https://gohtx.com/acadcolors.php
StephenSontag3
Thanks @BenSmith6. Do you add those color codes into an attribute/tag in the shapefile or dwg?  Trying to Export to CAD with specific styles but finding it hard to create a correct SEED file.
