Create Address Locator 'Fields Missing'
1967
01-09-2019 02:31 PM
LawrenceQuan
Hello, I'm using ArcGIS Pro and receive the following message when trying to use the Create Address Locator:
000037: Field(s) required by this style are missing
However, as you can see in the screenshot below that clearly all of the fields required are filled in.
The dataset I'm working with is Airdrie Roads.
Any assistance would be greatly appreciated.
BruceHarold
Esri Frequent Contributor
Hi Lawrence, scroll down a little more and check if you have supplied Street Name
LawrenceQuan
Thanks Bruce, that was it!
I was under the impression that the 'Full Street Name' field was the one, but it did seem a little odd that it wasn't a required field haha.
ShanaBritt
The Full Street Name field is not used for matching during the geocoding process. If the field is mapped the value from the reference data is written out to the geocode result to be used for labeling purposes.
