error 400 : unable to add feature service layer definition while publishing
2465
5
01-10-2019 02:51 AM
DelaereMickael
Hello everybody,
When trying to republish my survey with survey connect, i have this error message
did you ever see this message?
RobertoCardona
Change the name of fields in excel file
DelaereMickael
It does not work
i am going to read my pull data calculation again.
have an error 400 in the json because som precalculates positions return no adress a this point
JamesTedrick
Esri Esteemed Contributor
The pull data should not cause an issue in the publishing process.  Did you do any other changes to the form (add a question?)
DelaereMickael
Hello James,
Yes i added a question "commune" feed by pull function.
the question was a copy / paste from another form.
Today, i have just resolved the problem by deleting a view that joined the form's feature service with my workforce's assignments feature service.
Thank you for your answers.
PhilipQueen
Delaere Mickael‌ was the view you deleted the only view associated with your form? I'm receiving the same error while publishing, and suspect the associated views are the issue. Unfortunately, we have created multiple views and maps associated with our form, and so removing all views would be a large burden just to add a couple of fields.
