How to export simple dbf for import into Excel
8138
01-07-2019 06:58 PM
MalcolmLittle
I'm used to exporting an attribute table in ArcMap (version 10.4 in particular) for further analysis in Excel. Normally, I open the attribute table in ArcMap, click on the top-left icon, choose Export, and send everything to a DBASE table:
This produces a dbf file I can drag-and-drop right into Excel, and get a readymade table just as it was in ArcMap.
Tried the same in ArcPro (version 2.1.3), and figured out how to export to a DBF. However, instead of the above simple table of 3 columns, I get a lot of extraneous columns related to XML. Is there any way to replicate the same method that was so simple from ArcMap in ArcPro?
XanderBakker
Esri Esteemed Contributor
Just a question? Is the DBF intermediate format really necessary? Wouldn´t Table To Excel—Conversion toolbox | ArcGIS Desktop do the job to export a table to Excel?
DanPatterson_Retired
new world, but it works... total time 1 minute including screen grab stuff
MalcolmLittle
That didn't work for me without adding a ton of extraneous XML schema columns. Nonetheless, I found out how to export to txt, which provides the result I need after Text-to-Columns
Ahhh, you need some tools to test for me then
Table Tools for ArcGIS Pro
Table to csv, table to txt, to npy, excel to table
Lots of toys..
XanderBakker
