How do I separate data that iv'e collected in one survey into two (in order to compare data)
516
01-06-2019 04:28 AM
OliverMartin
Hi! I'm a beginner to GIS and Survey123, and therefore have a question which likely has a simple solution. I have searched around for solutions with little success, maybe because i'm not sure how to word the question.
I've conducted a survey with Survey123, and all the data is collected in one survey. However, my fieldwork was in two different locations, so I want to be able to comparatively analyze the data. For this, I need to separate the results into two different surveys, I believe. How can I do this?
Any advice would be much appreciated,
Thanks!
by Anonymous User
Not applicable
Hi Oliver,
When you say you collected two locations in the one survey, do you mean you used the one survey form and collected 2 records, each with a geopoint location, or you only collected one record with one survey form? If you only collected 1 record, how did you collect two different locations, did you have a repeat or two geopoint questions in you survey?
Can you share a copy of your xlsx form you used so we can try and better understand the way it is configured, and if you can access the feature layer settings online a screenshot of the fields and even export of the data collected to csv or excel?
Regards,
Phil.
