Attribute Assistant - Loading Alternate Configs
1159
01-02-2019 11:40 AM
RobertThomson
I have used AA quite success as part of the Local Gov Water Geometric Network but have never been able to use the Configuration Files pull down box at the the the bottom of the AA Config and Log File Window. (see attached).  Do I need a certain file name/configuration defined for custom configs?  I've tried .config files without any luck such as sewer.config, storm.config, etc.
Tags (1)
JoeBryant1
I'd also like to figure this out. I do see some, but not all, of the config files in my ConfigFile folder listed in the pull down. Ideally, I'd like to easily switch to different config files without renaming anything when I switch between different client's projects/mxds.
I am also confused about the naming convention of the current file. Is it always named loaded.aa.config? When is it named loaded.water.config? My water configs get renamed to "aa" when they are loaded.
