Get a utility network element from a selected feature
4603
10
12-27-2018 05:58 PM
EdwardBlair
Am assuming (but don't really know) that there is an equivalent in ArcGIS Pro/Utility Network to the Geometric Network for getting network elements from a selected feature.  There don't seem to be classes like ISimpleEdgeFeature or ISimpleJunctionFeature that subclass Feature.   And there doesn't seem to be anything like a GetNetworkElement() member on the Feature class.  But I suspect there is *some* way to do this.  If someone could point me in a direction here, that would be much appreciated.
Thx,
Ed
EdwardBlair
Please note, I'm aware of the documentation that describes fetching features from an element -- and that describes many other cool utility network functions as well.  What I can't seem to find is the process to go in the other direction -- that is, get network element(s) from a given feature.
Thx,
Ed
CharlesMacleod
Ed, I think this is what you are after:
UtilityNetwork.CreateElement
so, it might look something like this:
 var layer = map.GetLayersAsFlattenedList().OfType<UtilityNetworkLayer>().FirstOrDefault();
 if (layer != null)
    var utilityNetwork = layer.GetUtilityNetwork();
    //the feature class being a network source...
    var rowCursor = featureClass.Search(queryFilter);
    while (rowCursor.MoveNext())
       var currentRow = rowCursor.Current;
       var currentElement = utilityNetwork.CreateElement(currentRow);
EdwardBlair
Looks good. Thanks Charlie!
RichRuh
Charlie's code will get you the ArcGIS.Core.Data.UtilityNetwork.Element object that corresponds to a feature.  This is used for editing associations, setting starting points and barriers, and getting results back from a trace.  It does *not* give you access to the fine-grained topology for that feature.  For example, if a linear feature representing a conductor consists of five edges with taps between them, you cannot get back the five individual edges.  This capability is not yet exposed through the utility network.
RichardDumont
Rich, Any ETA on this?
RichRuh
None.
Our intent is that network topology operations should take place server-side using our tracing framework.  If you have scenarios or use cases that tracing doesn't currently fulfill, we would love to hear details.
Exporting topology information for a subnetwork (circuit) for the purposes of exporting to a third-party OMS, DMS, or analysis package will be supported at ArcGIS Enterprise 10.7.
Hope this helps,
--Rich
RichardDumont
Rich,
   The export of the topology was something I was thinking about, OMS/DMS (CIM) specifically, I heard about the export and I am hoping this will do what I am thinking.  I will check out 10.7 when it is available and I have the time.  (Billable time does come first.)  Thanks again!
Rich
StarletMyers
Rich,
Is this "export topology" now in 10.7?  What function should I look for in the API?
Star
RichRuh
Hi Star,
Yes, this is included with the Export Subnetwork geoprocessing tool.  You can call it from a geoprocessing model, Python, or by using the geoprocessing API in the Pro SDK.
--Rich
