Table frames display
606
12-28-2018 03:59 PM
ChrisTruty
I have a table frame on a layout that contains two fields, one of them being the feature label on the map.  When the feature labels are turned off, the table frame displays the appropriate data.  When I turn on the feature labels, the table frame data disappears.  I have other table frames that act appropriately regardless of the label settings but I cannot figure out why this one behaves the way it does.  I have tried recreating the layer from the feature class but it does the same thing as well.
Any help would be appreciated....thank you.
Tags (1)
TomBole
Hi Chris,
I'm not aware of any known issue with Table Frames that would result in the issue you're reporting. Unfortunately, without the steps/data to reproduce your issue there is very little troubleshooting that can be done. Are you able to contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
