Geo processing Service failed and not started
2109
12-26-2018 02:32 AM
Siva_SankaraReddy_T
I installed Visual Studio 17 with ArcGIS Run time for .Net 100.4 version and installed Local Server 100.3 as mentioned in Guide .
Local Server tested with below sample:
Local Server Services—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers opers.arcgis.com/net/latest/wpf/sample-code/localserverservices.htm
Local server is Starting and then failed when i am using Geo processing service. but when  i am selecting the Map service and Feature service it stated well . as show in below.
Please provide solution for this issue.
JenniferNery
What is the Error when you start LocalGeoprocessingService? I am not sure if this blog post will apply to you. You can also use Local Server Utility to troubleshoot.
Siva_SankaraReddy_T
Hi Jennifer,
Thanks for your reply.  attached the error snap.
MichaelBranscomb
Esri Frequent Contributor
You will need to enable additional deployment options for geoprocessing - for more information please see Local Server—ArcGIS Runtime SDK for .NET | ArcGIS for Developers.
Cheers
Mike
