ago import fails in ArcPro Python
1422
6
12-18-2018 06:24 PM
MaazaMekuria
I am not sure why but I am running Pro 1.4.1 . The same code run on ArcGIS 10.6 and I am wondering if upgrading to pro 2.2 will restore the functionality?
DanPatterson_Retired
What code are you using?
MaazaMekuria
The python script aborts ass soon as it begins with an error message on not finding ago (import ago).
There is no module called ago, you can import other "a..." stuff that is related to esri products
import ago
  File "<ipython-input-1-7ff8aea8a94b>", line 1, in <module>
    import ago
ModuleNotFoundError: No module named 'ago'
import arcgis
import arcpy
So perhaps you might want to show the script that you are using so people can discern what it is you are really trying to import
MaazaMekuria
I think there is a module ago and it is not in Pro 1.4.1 . check out ESRI's website if you wish.  As at first, the same code runs in 10.6 (beginning with 10.3).
MaazaMekuria
if it works in 10.6 and it doesn't work in Pro, it needs to be installed for Pro, (assuming it works for both environments)... they don't share modules, Pro's environment is totally self contained and isolated from ArcMap.
You probably want the "arcgis " module if you are trying to administer AGOL from Pro
