How can I change properly the DataSource of a featurelayer?
767
12-18-2018 03:44 AM
MarioD_Amico
I have followed this example:
arcgis-pro-sdk-community-samples/ChangeLayerDataSource.cs at master · Esri/arcgis-pro-sdk-community-...
but, in my opinion, it doesn't work properly.
I have two featureclass in the same GDB, and a layer on the map has source GDB\featureclass1. I change the DataSource of the layer using the code in the example so that the new DataSource is GDB\featureclass2.
When I delete GDB\featureclass1 the layer is removed from the map, I'm wandering why this is happening because now its DataSource is changed.
Any suggestion?
