Arcade Expressions, Conditionals and PopUps
2809
12-06-2018 02:11 PM
deleted-user-jxpbpbjlZInj
I have a hosted feature layer where there are two fields I'm concerned with: Status and Assignment_Type
The status can be reported, assigned or completed. If it's assigned, then an assignment type is given. I want the popup to display the Assignment_Type only when the Status field = "Assigned"
I have written:
If($feature.Status=='Assigned'){
return ($feature.Assignment_Type)
else{
return ""
However, the Assignment_Type shows up unconditionally!  What am I doing wrong?
Oh I was over-complicating it! For anyone else that may come across this thread, I would like to add that additionally, I needed there to be a bit of text prior to the attribute so my final expression was the following:
IIf($feature.Status=='Assigned', "Action Assigned: " + $feature.Assignment_Type, "")
Thank you for your help.
KellyGerrow
Esri Alum
try this:
IIf($feature.Status=='Assigned', $feature.Assignment_Type, "")
Logical Functions | ArcGIS for Developers
https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2017/07/18/conditional-field-disp...
IF this doesn't work, can you share your map?
-Kelly
