SearchCursor object() takes no parameters
1813
5
12-06-2018 07:52 AM
Che-YiHung
Hi I'm just learning the function of SearchCursor
this is my code here
import arcpy
points = r'D:\GIS\turto\pop.shp'
with arcpy.da.SearchCursor(points,['iso_a2', 'adm0_a3']) as citycursor:
    for x in citycursor:
        print(x[0]);
and the error just show:
D:\Users\Jay\PycharmProjects\learn\venv\Scripts\python.exe D:/Users/Jay/PycharmProjects/learn/search.py
 File "D:/Users/Jay/PycharmProjects/learn/search.py", line 10, in <module>
TypeError: object() takes no parameters
Process finished with exit code 1
I followed the tutorial of this one
6 - Search Cursors - Arcgis Scrpting with Python - YouTube
and I checked the syntax and other examples, all didnt help
the sitauation
I wonder what I do wrong
Please help me, thank you
MitchHolley1
Please remove the ; at the end of the print statement.  I tested a search cursor on your dataset without any errors. What python version are you using?  Can you import arcpy from the interactive python IDE environment without errors?
DanPatterson_Retired
semi-colon is ok in python 3 at least
a = [1,2,3,4]
for i in a:
    print(i);
Che-YiHung
Hi, I can use other arcpy funtions such as search by location, so it means the arcpy in pycharm is imported correctly, right?
I'm using the python 2.7 which came with ArcGIS 10.5
I was wondering what was missing
can the shapefile be viewed in ArcMap and can you confirm that the fields are indeed there
Che-YiHung
yes, I just downloaded from the Nature Earth website for the tutorial. And as Mitch tested, the data is fine.
