Modifying IdentifyWidget for multi-selection
1596
5
12-06-2018 12:02 AM
shamnaspc2
Hello Robert,
I am currently using your identify widget, and I have a question regarding modifying it. How do I modify the code in Widget.js to allow the fill in selected polygons to remain without disappearing when I select another polygon? Currently I have modified the widget to have a ongoing list so that I can add and remove multiple polygons from the map to the results list as well as removing them. So I just need the map to also reflect which polygons have been selected using the polygon fills, and remove them when their results are removed as well.
Thank you for your assistance,
Shamnas
Tags (1)
RobertScheitlin__GISP
Shammas,
   That is because the draw tool uses the same graphics layer in the _onDrawEnd function. You would need to make this change:
      _onDrawEnd:function(graphic, geotype, commontype){
        this._hideInfoWindow();
        this.drawBox.clear();
        this.map.graphics.clear();
        this.map.graphics.add(graphic);‍‍‍‍‍‍
Shammas,
  Just look for
this.graphicsLayer.clear();
shamnaspc2
Thanks! I commented them out and it worked. However, the points that I clicked on did not disappear when I remove them from the results. Attached a picture showing the effect.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Shammas,
shamnaspc2
Thank you so much! That helped me a lot.
