Survey123 - Use position from webmap?
521
12-03-2018 05:23 AM
Jon_AndersKrokann_TEN
We have a webapp published on our webpage where people use the location button to find information about utilities near there houses. From the pop-up, a survey can be loaded. Is there any way to make the position in the survey be the same as in the webapp?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Jon,
I've done this before when the input feature service contains the latitude/longitude in fields.  You can pass this information from these fields using the center option.  See the following help document.  Ex:
https://survey123.arcgis.com/share/36ff9e8c13e042a58cfce4ad87f55d19?field:surname=Klauser&center={latitude},{longitude}
by Anonymous User
Not applicable
As Jake stated above and using the "Custom URL" for transferring data would be the most effective way of transferring data between the two applications. This is another good resource when learning to do this - https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...
