Trace object
4851
12
11-29-2018 06:05 AM
IvanoGasco
I have a polyline 3d feature which I want to trace to create some polygons.
Why the z coordinate is not traced (snapping is ON)? Is this not yet available?
Tags (1)
DanPatterson_Retired
It seems you have some steps
Create segments by tracing other features—ArcGIS Pro | ArcGIS Desktop
Specify an elevation for 3D features—ArcGIS Pro | ArcGIS Desktop
but I suspect for polygon output, you have the option of assigning 1 Z value
IvanoGasco
I do not want to specify elevation. I would like it is fetched from the traced object, but it is set to 0.
By default, z-values are applied to new features in the following ways:
  • In maps, the default z-value is set to zero (0).
  • In scenes, z-values are derived from the active elevation surface when you click the scene.
IvanoGasco
I do not agree. In maps, with Z-mode off and snapping on, the behaviour is as follows:
new features fetch the elevation (if available) from snapped feature
  • new features created with "trace selected features only" always set z to 0 even if traced features had z values <> from 0
by Anonymous User
Not applicable
Ivano,
As you suspected, this is not available yet in Pro. When tracing features with the elevation mode off, the resulting segment z values are 0. We'll work on it after 2.3
IvanoGasco
This would be a great improvment in 3D editing.
IvanoGasco
News about creating 3D polygons by tracing 3D polylines?
by Anonymous User
Not applicable
No progress for 2.4, still on the list.
AntonelloRizzo_Naudi
Hi Sean, I am working on ArcGIS Pro 2.5, and unfortunately the 'trace' tool is not maintaining the 'Z' values of the traced object.  Is this something with Pro or am I missing something. Thanks
