Connect FileMaker to ArcGIS?
3627
11-28-2018 02:34 AM
SilvanStöckli
Hello
Is it possible to directly access a FileMaker Database from ArcGiS?
I installed the ODBC-Driver for both programs but I could not figure out how I can "add" the FileMaker-data into ArcMap.
Is it also possible to Edit Data in the FileMaker Database directly in ArcGIS?
Thank you for your help!
I use ArcGIS 10.3 and FileMaker Pro 16
JonathanFarmer_oldaccount
Hi Silvan,
Unfortunately, FileMaker is not one of our supported DBMS platforms. For a list of what we do support, see the link below.
Supported database management systems—Help | ArcGIS Desktop
Jonathan
JamesDrew
I'd be interested in this as well!
BinuAlexander
I have been able to connect FileMaker Pro via ODBC to MS Access and then on to ArcGIS . Worked fine for me. I did this with version FMPro v17 for a short project. Should work even now.
