XML pasring error when opening report in Word
1042
11-26-2018 07:47 AM
ClaireInbody1
I am receiving xml parsing error on some records from the survey123 report template. However it will work with other records. It appears to be if certain repeat data is not entered in it will give an error. Anyone else seen this issue?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Claire,
Can you share the docx with the error and possibly the XLS file (and ideally, the data that caused this error)?  In debugging similar errors, this type of error appears to be very dependent on the data being submitted.
