Multiple copies of a feature layer in the web map for offline use
2016
11-23-2018 01:20 AM
UndrakhBatkhishig
I've just intsalled Collector for ArcGIS beta version for testing offline map filter by data type. Now we're focusing on offline web map including multiple copies of a feature layer (not hosted feature layer) in the map that have different spatial filter(Query). But still facing the error "download failed" when web map has duplicated feature layers.
Is there any way to solve this issue ?
by Anonymous User
Not applicable
Hello Undrakh,
"A feature service published to ArcGIS Server or Portal for ArcGIS that contains two layers based on the same feature class cannot be taken offline, edited, and synchronized.
For example, if you add your roads feature class to your map to display all roads, add the same roads feature class and set a definition query on it to display roads that are under construction, and publish a feature service from the map, you cannot take the feature service offline for editing and synchronize your changes when you are online."
Prepare data for offline use—Documentation | ArcGIS Enterprise
DerekLaw
Esri Esteemed Contributor
Hi Undrakh,
Please take a look at this blog on feature layer views,
Take the same layer offline twice in Collector using feature layer views
Hope this helps,
