arcpy.SynchronizeChanges_management slow
2654
11-22-2018 02:12 AM
HiteshJilka
Parent Enterprise GDB: 10.3.1
Child Enterprise GDB: 10.4.1
We have standalone python sync script which sync changes in both direction.  We noticed that even for few changes the sync script takes more than 30 mins and if we sync in 1-Way direction, it takes appr 15 mins even if there are no any changes. But if we sync changes from ArcMAP (right click SDE connection --> Distributed geodatabase --> Synchronize changes), it takes less than 2 mins to complete (both 2-way and 1-way direction).
As we are using Network license, I found from ESRI community that license might take some time to load but I tested and found it takes less than 30 seconds. Also, we have set "import arcpy"  but result is same.
Would anyone please help me on how we can speed up the process on standalone python script..
HiteshJilka
Yes it was because of arcpy logs geoprocessing history into GDB.
You need to add either one of following line of code after "import arcpy" to turn off geoprocessing history..
arcpy.gp.logHistory = False
OR
arcpy.SetLogHistory(False)
LelandSnyder
Did you ever figure out why this may be happening? I am experiencing something very similar.
HiteshJilka
OR
LelandSnyder
Thank you, this solved the problem. Sync takes less than a minute now.
