Customise print widget
3029
6
11-20-2018 09:22 AM
GarethYoung1
Robert Scheitlin, GISP
Robert,
Is there a way to customise the options on the print widget?
Or can you remove them all together?
Gareth
Tags (1)
RobertScheitlin__GISP
Gareth,
  Did this work for you?
Sure which do you prefer? If you want to remove certain option then just set the display style of the html elements in the print widgets templates\Print.html file. If you which to remove the whole advanced button then change line 486 in the Print.js to
  domStyle.set(this.advancedButtonDijit, 'display', 'none');
Gareth,
GarethYoung1
Thanks Robert, that worked a treat
Is there a way to remove some layout and format options from the print widget?  I would just like A4 portrait and landscape and as a PDF.
GarethYoung1
Robert, is there a way to change the progress bar in the print widget?
Gareth,
   The way I do it is add a css rule to the dojo-override.css
/* Progressbar*/
.claro .dijitProgressBarIndeterminate .dijitProgressBarTile {
  background: #efefef url("images/progressBarAnim2.gif") repeat-x top;
