Disable button to show map
710
11-19-2018 04:47 AM
LeifNorberg1
When creating a Survey123 form with multiple maps (using this method), the maps gets replaced by buttons in the browser. I would like to show the maps without first having to press the button. I can't find the settings for this and can't seem to add CSS to fix it. Any suggestions?
The html for the button:
<button class="btn btn-survey123 setLocationBtn" type="button">Ange plats</button>
The html for a pressed button (when the maps are shown):
<button class="btn btn-survey123 setLocationBtn" type="button" style="display: none;">Ange plats</button>
JamesTedrick
Esri Esteemed Contributor
Hi Leif,
If you set the geopoint questions as required, the map will display when the form loads
