Append data to hosted feature layer has stopped working
997
11-16-2018 10:28 AM
RWTQTST
Append data to hosted feature layer seems to process normally (success message), but no new data gets added to the layer.
This workflow was operational a few days ago.  I am using a zipped shape file.
#AGOL
Tags (1)
JakeSkinner
Esri Esteemed Contributor
As a workaround, you can try the following tool if you'd like:
https://community.esri.com/docs/DOC-11621-update-hosted-feature-service-with-feature-class
RWTQTST
AGOL Append is still not operating properly, but a work-around using ArcMap was successful:
1)  make a local copy for editing,
2)  then append in ArcMap,
3)  then synchronizing back to AGOL
AGOL seems intermittent, as I had to repeat step 1 several times until data came through to ArcMap (10.5.1); zero rows otherwise.
