The field is not nullable
8329
12
11-15-2018 11:03 AM
TonyAlmeida
MVP Regular Contributor
I have a feature layer that i am trying to populate a field from another layer using a Dictionary/spatial join. I am getting "The field is not nullable" on line 38. Some feature are not within the polygonLayer = 'Soils", so i can see why it's not populating the Class_ID field but how do I by pass this "The field is not nullable" and keep going regardless if the point layer field is blank?
# Import arcpy module
import arcpy
import sys
import traceback
# scratch spatial join feature
sjpoints = "In_memory\SpJoin"
# define the field list from the spatial join to transfer
# you can add more field names such as: ["TARGET_FID", "Field", "AnoterField"]
sourceFieldsList = ["TARGET_FID", "Class_ID"]
# point feature that will be updated
pointLayer = "Bld_Class"
# polygon feature that will be used
polygonLayer = "Soils"
# define the field list to the original points
updateFieldsList = ["OID@", "Class"]
# Allow overwrite of join results
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(pointLayer, polygonLayer, sjpoints)
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as cursor:
    for Row in cursor:
        keyValue = Row[0]
        if keyValue in valueDict:
            print keyValue
            for n in range (1,len(sourceFieldsList)):
                Row = valueDict[keyValue][n-1]
            cursor.updateRow(Row)
del valueDict
arcpy.Delete_management("In_memory\SpJoin")
JoeBorgione
Take a look at the python try/except block.  It will allow you to 'try' and do something, but in the event of an exception, let's you keep going.  Here are few resources  to check out:
Try and Except in Python
Python Try Except
8. Errors and Exceptions — Python 3.7.1 documentation
8. Errors and Exceptions — Python 2.7.15 documentation
Here is a simple example from a script I've run:
try:
    arcpy.MetadataImporter_conversion(SourceFeatureClass,TargetFeatureClass)
    print 'Successfully Imported Metadata From {} To {}'.format(SourceFeatureClass,TargetFeatureClass)
except Exception as err:
    print err
TonyAlmeida
I did try, try and except.
IT looks like it once it gets to a records that is blank it doesn't continue. There is not error.
import arcpy
import sys
import traceback
try:
    with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as updateRows:
        for updateRow in updateRows:
            keyValue = updateRow[0]
                    updateRow = valueDict[keyValue][n-1]
                updateRows.updateRow(updateRow)
    del valueDict
except Exception:
    pass
DanPatterson_Retired
careful... you have a method and an object with the same name, may not be the issue now
TonyAlmeida
I made some changes. Thanks for pointing that out. I grab the code from
Richard Fairhurst Turbo Charging Data Manipulation with Python Cursors and Dictionaries
        for Row in cursor:
            keyValue = Row[0]
    del valueDict
JoeBorgione
You may want to put some print statements in your code and see where it's failing.  You mention 'blank': blank is not null.  Blank is blank.  I also notice the lack of setting a workspace although you set feature class variables as if you have; perhaps you have set the workspace in your working script?  Line 7 has a little problem too:you should either escape that slash or use 'r' to do it for you:
# yours:
sjpoints = "In_memory\\SpJoin"
#or
sjpoints = r"In_memory\SpJoin"
TonyAlmeida
I have set my work space and changed sjpoints to
arcpy.Delete_management(sjpoints)
I have added a print statement.
{0: (u'C_ID3889701100',), 1: (u'C_ID3890500000',), 2: (u'C_ID3890200000',), 3: (u'C_ID3890001000',), 4: (u'C_ID3889900000',), 5: (u'C_ID3889301100',), 6: (u'C_ID3889400000',), 7: (u'C_ID3889600000',), 8: (u'C_ID3889500000',), 9: (u'C_ID3889800000',), 10: (u'C_ID3889801000',), 11: (u'C_ID3889701000',), 12: (u'C_ID3888500000',), 13: (u'C_ID3888601000',), 14: (u'C_ID3825200000',), 15: (u'C_ID3825100000',),  16: (None,), 17: (None,), 18: (None,)}
Runtime error
  File "<string>", line 44, in <module>
RuntimeError: The field is not nullable. [Class_ID]
JoeBorgione
That's not telling us much, since we don't know what you result you are printing.  The idea of using print() to trouble shoot is to plug them in along the way to see what has succeeded before the failure.
RandyBurton
You reference Richard Fairhurst‌'s article which describes a process using a dictionary to avoid using a join.  I notice in your code you are using a join before creating a dictionary:
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}‍‍‍‍‍‍
First, can you verify the join works as expected.  I'm not sure the TARGET_FID and OID@ are providing the link you need to make the dictionary technique work.  I am making the assumption that you want to capture some attribute of the polygon feature and save it as an attribute with all the points that fall inside the polygon.  Perhaps you can clarify if this is not the case.
As an additional test, you can print some or all of the valueDict to see if there are null/None values associated with the various dictionary keys.  You could add a test in the update block, that if the dictionary key's value is None/null, then skip the update or substitute a default value.  As written, the block is skipping any updates if the keyValue is not in the valueDict.
Hope this helps.
TonyAlmeida
Yes i am doing a spatial join, yes the join is working I checked various times.
You are correct that i am trying to capture some attributes of the polygons features and save it as an attribute with all the points that fall inside the polygon. Not sure how to add a test in the update block that you mentioned.
