Legend not updated in exported layout (arcpy.mp exporting multiple maps)
2405
11-08-2018 10:19 PM
KentaOkuyama
I'm using arcpy.mp to export multiple layers at once, but having a trouble that legend is not updated.
Each layer is successfully exported as separate JPEG file by the code below. However, the legend attached to each exported output is all the same (legend of the first layer).
I usually run my script as standalone from Jupyter notebook. When I run the code below in python window within ArcGIS pro, legend was successfully updated in each exported output.
If anybody has any idea on why it cannot be done by standalone, I would really appreciate it.
ArcGIS Pro 2.2
# This is the code I ran
aprx = arcpy.mp.ArcGISProject(r"C:\Users\kenta\Documents\ArcGIS\Projects\CoHRE_Collaboration\CoHRE_Collaboration.aprx")
maps = aprx.listMaps("Oki")[0]
layers = maps.listLayers("mean*")
layout = aprx.listLayouts("Oki_layout")[0]
for layer in layers:
   layer.visible=False
   layer.visible = True
   layout.exportToJPEG(r"C:\Users\kenta\Dropbox\Collaboration\CollaborationOki"+ "\\" + layer.name + ".JPEG")
   layer.visible = False
DavidMatthews3
Hi Kenta,
I know this is old but did you ever resolve this issue?
Cheers
SydneyWagner
Hello All,
I saw a couple of posts about this topic but no solution. My code makes a set of layers visible, one at a time, and exports a layout with each layer visible. I found that if I toggle the legend visibility as well, that I can get the legend to update as expected in the exported layout. To do this, I pulled the legend element (in my case, I have only one legend) from my layout object, changed the visible property to True, completed some other operations, then changed the legend visibility back to False.
Hope this helps someone. Code below.
Sydney
# Iterate through layer objects.
for lyr in layers_to_export:
    # Make desired layer visible and make the legend visible.
    lyr.visible = True
    legend = layout.listElements("LEGEND_ELEMENT")[0]
    legend.visible = True
    if title_bool:
        # Change title text
        title = layout.listElements("TEXT_ELEMENT", title_element_name)[0]
        title.text = title_start + lyr.name
    # Export layout to PDF
    layout.exportToPDF(os.path.join(output_dir, f"{lyr.name}.pdf"))
    # Make layer invisible again, toggle legend off
    lyr.visible = False
    legend.visible = False
Mya_Yazbek
I was having this issue with a for loop to export a series of maps. Your response with toggling legend visibility fixed my problem. Thanks!
DrewSparks
In case anyone comes across this issue, I found a solution that worked for me. I'm currently using ArcGIS Pro 3.3.2 and running a python script in IDLE that exports a PDF of a layout after toggling a set of layers on and off.
Toggling the legend's syncLayerVisibility on and off before exporting the PDF (and after all the layer visibilities had been changed) worked to refresh the legend:
pLegend = pLayout.listElements("LEGEND_ELEMENT","Legend")[0]
pLegend.syncLayerVisibility = False
pLegend.syncLayerVisibility = True
