Create Map Tile Package of Basemap (export)
7398
11-09-2018 01:48 PM
BrianKaplan
I'm trying to run the tool Create Map Tile Package and use one of the basemaps that are labeled for export but I get the following message that the layer type is not supported.  I tried this in Pro 2.2.3 and ArcMap 10.5.1.
The tool in Pro from the main ribbon called Download Map works with this layer to create a tile package.  But I would like to get the "Create Map Tile Package" tool working because the users I support are mostly using ArcMap.
So why isn't the Create Map Tile Package" tool not working with this Layer?  I tried several of the "(for Export)" layers to no avail.
------Error Message-----
Start Time: Friday, November 9, 2018 4:32:42 PM
Layer type is not supported: Map3/World Street Map (for Export)
Failed to execute (CreateMapTilePackage).
Failed at Friday, November 9, 2018 4:32:44 PM (Elapsed Ti
Brian
Tags (3)
Scott_Harris
This "Idea" has some relevant info:
Reinstate Esri Basemap for offline use via ArcGIS Pro
In essence, now you can use the "Download Map" functionality of Pro:
Take a map offline—ArcGIS Pro | ArcGIS Desktop
MarkBockenhauer
You will be able to use the Create Map Tile Package tool on the exportable tile layers in the Pro 2.3 release...  or download map, as mentioned.
BrianKaplan
Thanks for the replies.   There is also separate tile package creator Esri nicely provides.   https://github.com/Esri/TilePackageKreator.  The ArcMap user apparently needs to use this tool.
