Pandas Pivot Table with rounding
24517
11-09-2018 08:21 AM
ZacharyHart
Honored Contributor
I'm attempting to add in subtotals to a pivot table from a very basic array. The first example I provide I derived on my own, but this has no subtotals for each group.
The second example I borrowed and honestly I don't really get how it works just yet, and I cannot get a round to work.
pd.pivot_table(df.round({'ACRES':1}),values = 'ACRES', index = ['SUPER_TYPE','STRATA', 'OS_TYPE'], aggfunc=np.sum, margins = True)
Returns:
2nd example:
df.groupby(['SUPER_TYPE']).apply(lambda sub_df: sub_df.pivot_table(index=['STRATA', 'OS_TYPE'], values=['ACRES'], margins=True) )
I'm guessing there are a number of ways to go about this. Thanks in advance!
Tags (1)
DanPatterson_Retired
ZacharyHart
Honored Contributor
Dan Patterson, thanks for that...I didn't know it would be so simple. Here is what I came up with for my test code before I roll it up into a function. I've always got open ears for improvement! Edit: my pivot table fails to include a grand total. Any suggestions?
table = "\\\\fileServer\\MAP_PROJECTS\\LV_WEB\\SDE_CONNECTIONS\\LV_NEXUS.sde\\LV_NEXUS.DATAOWNER.NORTHEAST\\LV_NEXUS.DATAOWNER.NE_HARVEST_OPS"
HUID = "669-NMTC-139"
whereClause = """ "LV_HARVEST_UNIT_ID" = '{0}' """.format(HUID)
print(whereClause)
tableArray = arcpy.da.TableToNumPyArray(table, ['STAND_NUMB', 'SUPER_TYPE','STRATA', 'OS_TYPE', 'SILV_PRES', 'ACRES'], where_clause = whereClause)
df = pd.DataFrame(tableArray)
report = df.groupby(['SUPER_TYPE']).apply(lambda sub_df: sub_df.pivot_table(index=['STRATA', 'OS_TYPE', 'STAND_NUMB', 'SILV_PRES'], values=['ACRES'], margins=True) )
np.round(report,1)‍‍‍‍‍‍‍‍
Zachary
I have a few toolset post on the Code sharing site, I don't use pandas, preferring numpy instead, but feel free to examine coding.
Table Tools, has a crosstab/pivot table equivalent, amongst other things
/blogs/dan_patterson/2018/02/12/table-tools-a-set-of-tools-for-working-with-tabular-data
ZacharyHart
Honored Contributor
Dan Patterson‌ thanks! there's some real gold in there. I've bookmarked these and downloaded your table tools.
I ended up getting some help on SE and found an easy way to move the totals. Thanks again Dan!
