Change military time display in record table
2299
11-08-2018 01:26 PM
Katie_Clark
MVP Regular Contributor
I am building my first survey with Survey123 Connect for ArcGIS. I want a "Crew Start Time" and "Crew End Time" field, which I have successfully added to the survey.
It looks like when the data is displayed in the data table, it is automatically entered in military time. Is there a way to change this format so that it says AM or PM?
Thanks for any help!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
MarisaClaggett
Hi Katherine,
Have you taken a look at the following geonet blog post?
https://community.esri.com/groups/survey123/blog/2016/04/17/dates-and-time-in-survey123-for-arcgis
It might be helpful for you.  Afer some testing on my end, I have not been able to create an "AM" or "PM" value that would show up in your table when only using a time question.  When using a dateTime field though, the field value in AGOL will display a non-military time with AM or PM.
I would recommend opening a ticket with Esri Support to perhaps log an enhancement.
Best,
Marisa
Katie_Clark
Marisa,
Thank you so much for your response! I did look at that blog post, but I hadn't tried using the dateTime field type since I only wanted to time to post in that field. However, I'll look into that a bit more and play around with it, thanks for the suggestion!
Best,
Katherine
Best,
Katie
Miguel-Fernandez
Any update on this?
Miguel Fernandez
