Create Query URL Parameter in Pop-Up in one WAB to launch another WAB app
2815
5
11-07-2018 11:12 AM
by Anonymous User
Not applicable
Hello!
I am trying to create a Query or Find URL Parameter that I can put as a hyperlink in a pop-up for an internal WAB application we have that is used by another department.  Essentially what I want is when you click on the the hyperlink in the pop-up that it launches another WAB website application (our parcel viewer website), queries the parcel layer and shows the user a result (the found parcel).  I have tried unsuccessfully to get this to work.  I don't know if the layer doesn't support what I am trying to query (the PARID field) or if I am totally goofing the syntax.
WAB Website I'm trying to query: https://maps.onslowcountync.gov (hosted by a vendor on their server)
Query Layer: Parcels (Layer ID=51)
Query Field: PARID (alias PAR ID
Query I have gotten to work is:  /?LayerID=51&FeatureID=42171633 (preceded by the above url)
Problem: I want to query the PARID field, not the FeatureID field.  PARID is my primary key.
Any help or suggestions would be great!
Thanks!
RobertScheitlin__GISP
Angelia,
  Strange The proper query syntax should look like:
&query=Census_8491,POP2000=1211537
http://doc.arcgis.com/en/web-appbuilder/manage-apps/app-url-parameters.htm#ESRI_SECTION1_ED1AF7A40AB...
When using a WAB app.
But that app in your link is NOT a WAB app. It appears to be just a custom JS API app. Looking at the apps main.js the url parameters you are using are what is coded for (i.e. the layerID and ObjectId(s) of a feature).
Angelia,
by Anonymous User
Not applicable
Thanks for the reply Robert.  Does this mean I can't query the PARID field in the feature using URL parameters?  It is a field in the data. Here is the rest services for the feature layer: https://arcgis4.roktech.net/arcgis/rest/services/Onslow/GoMaps4/MapServer/51
Angelina,
  That is correct, you can not unless the apps developer adds the ability to query a certain field verses just ObjectId(s)
by Anonymous User
Not applicable
I will ask today and let you know!  Thanks again Robert!
No problem. Don't forget to mark this question as answered as this is now in your app developer court.
