I am grayed out from signing in or out of ArcGIS Online in ArcMap.
2388
8
11-07-2018 07:28 AM
APaulsen
We started with an online account before getting Enterprise. I cannot switch between those accounts when one is grayed out. I want to open and republish the maps from our online account and re share them to our Portal. How do I resolve this?
AdrianWelsh
MVP Honored Contributor
Andrew,
If you close and re-open ArcMap, does this still happen? Or maybe close all instances of ArcMap?
Worst case scenario, reboot the PC and only open ArcMap to make sure there isn't a lock somewhere.
AdrianWelsh
Andrew,
APaulsen
It just let lose or changed. Weird. Learning software is challenging with a lot of bugs.
AdrianWelsh
Andrew, what version of ArcMap are you running?
You can mark a response as 'correct response' or answered (or whatever it says) to close it out.
APaulsen
Version 10.6.1
AdrianWelsh
That's good to know. If it was a lower version, I'd suggest upgrading! Yeah, keep an eye on it and report back if you're seeing more issues.
Thanks.
APaulsen
Yeah it did it again. Once it released I could use our other login for our ArcGIS Online and open the map then saved a copy, then signed in to our portal and tried to share the service, but not working for some reason. Now it is grayed out and automatically connects to our portal.
AdrianWelsh
APaulsen
It clicked. I need to connect to the online portal vs local portal in Administrator.
