getWebLayerSharingDraft not found
3211
11-02-2018 06:31 AM
BenJenkins
When trying to create an sd draft file with <map object variable>.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", "nAmEblAH") I get the error "'Map' object has no attribute 'getWebLayerSharingDraft'". I'm following the example exactly as its shown here FeatureSharingDraft—Sharing module | ArcGIS Desktop and can't work out the issue. Is this a known bug? I'm using pro version 2.1.2.
BenJenkins
I used CreateWebLayerSDDraft instead, it worled.
DamasoAvalos_Ruiz1
Hello
Did you find any reason why this happens?
I am guessing it is because Arcgis Pro run Python 3.6 and ArcGis server still run under Python 2.7. But I am just guessing. I got lost among all those ESRI help online web pages.
by Anonymous User
Not applicable
The arcpy.sharing module (containing getWebLayerSharingDraft) was introduced at ArcGIS Pro 2.2 to provide a better experience when sharing web layers over the previously existing function CreateWebLayerSDDraft. The original function is provided only for backward compatibility.
Introduction to arcpy.sharing—Sharing module | Documentation
LiamAbbate
That still does not address the issue of the error of:
name 'getWebLayerSharingDraft' is not defined
