Generate Token in REST
5727
8
10-31-2018 08:24 AM
joerodmey
Tryhing to generate an AGOL token using REST. WHat I have so far:
https://www.arcgis.com/sharing/generateToken HTTP/1.1?f=json&username=USERNAME&password=PASSWORD&client=requestip
Error I get:
{"error":{"code":400,"messageCode":"GWM_0002","message":"Invalid URL","details":[]}}
JakeSkinner
Esri Esteemed Contributor
Hi Joe,
Here is an example on how to do this using python:
import requests, json
tokenURL = 'https://www.arcgis.com/sharing/rest/generateToken'
params = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'http://www.arcgis.com'}
response = requests.post(tokenURL, data = params, verify = False)
token = response.json()['token']
JakeSkinner
Hi Joe,
joerodmey
I don't have the option to use Python, I have to use REST directly. Reason being is that I'm using Integromat and webhooks
joerodmey
JakeSkinner
I'm not familiar with Integromat or webhooks, but I believe you need to create a POST request when generating a token.  For example, you could use Postman to do this.  Try this app and check to make sure your parameters are correct.
RandyBurton
Have you tried adding it to the URL:
&token=yourtokenvalue
joerodmey
Is there an option to receive the expiry time in minutes instead of milliseconds?
How can you remove the word token and expiry from the JSON response?
joerodmey
Can you format the JSON response to just have the token and no other text?
JakeSkinner
In the python example I provided the response is a dictionary, so I can call the appropriate key ('token') to only receive that text.
