Feature Class to Feature Class
9024
10
10-29-2018 03:00 PM
GIS_geek
I work on a project that is very repetitive and would like to have a python script for it. I am trying to export a feature class from SDE which contains an expression. The geodatabase has been created and I have the following code,
# Import system modules
import arcpy
from arcpy import env
# Set the workspace
arcpy.env.workspace = "Database Connections\ADMIN Edit.sde\GIS.DBO.SewerCollectionNetwork"
ArcSDE = arcpy.env.workspace
env.overwriteOutput = True
# Set local variables
inFeatures = ['sewer']
outputDatabaseLocation = "C:\Users\gis\Desktop\sewer\CCTV.gdb"
outputFeatureClass = "SewerMains"
delimitedField = arcpy.AddFieldDelimiters(arcpy.env.workspace, "OWNER")
expression = delimitedField + " = 'LOCAL'"
# Export feature class
print("Exporting feature class to CCTV geodatabase")
arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outputDatabaseLocation, outputFeatureClass, expression)
I get the following error,
  File "B:\Scripts\Python\ArcSDE Maintenance\CCTV Feature Class.py", line 25, in <module>
    arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outputDatabaseLocation, outputFeatureClass)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\conversion.py", line 1891, in FeatureClassToFeatureClass
    raise e
RuntimeError: Object: Error in executing tool
I have tried using FeatureClassToGeodatabase and FeatureClassToShapefile with success, but I need to be able to add an expression to only export specific values from a field.
Any help will be appreciated.
DarrenWiens2
Hmmm, a string inside brackets means "list of one string" in Python, but I don't work with SDE.
AdrianWelsh
MVP Honored Contributor
Hector,
Take a look at this document:
Feature Class to Feature Class—Conversion toolbox | ArcGIS Desktop
It mentions where and how to add an expression. Here is the example:
# Name: FeatureClassToFeatureClass_Example2.py
# Description: Use FeatureClassToFeatureClass with an expression to create a subset
#  of the original feature class.
import arcpy
# Set environment settings
arcpy.env.workspace = "C:/data/GreenvalleyDB.gdb/Public Buildings"
inFeatures = "buildings_point"
outLocation = "C:/output/output.gdb"
outFeatureClass = "postoffices"
delimitedField = arcpy.AddFieldDelimiters(arcpy.env.workspace, "NAME")
expression = delimitedField + " = 'Post Office'"
# Execute FeatureClassToFeatureClass
arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outLocation,
                                            outFeatureClass, expression)
GIS_geek
Thanks for the reply.  This is the documentation I have been following and still getting errors.
AdrianWelsh
Oh, I see that now. Sorry about that. If you were to not include the expression, does the script work ok? I guess I'm trying to figure out where the error is coming in at (maybe it is with the syntax of the expression)?
GIS_geek
I am not sure. I have tried it without the expression and it does the same thing.  I have double checked my variables to make sure everything is correct and still cannot find what I am doing wrong.
BalajiVeera
Try to change
expression = "OWNER = 'LOCAL'"
since SQL SDE
GIS_geek
Hello Balaji,
I tried your suggestions and got the same error.
DarrenWiens2
Are you sure this is correct? inFeatures should be a Feature Layer, not a list.
edit: you should also get in the habit of using forward slashes or raw string notation (e.g. r'path') for paths, otherwise you risk introducing unwanted escape characters.
GIS_geek
Hello Darren,
Yes. This is my layer in SDE.
DarrenWiens2
