Create one large polygon with multiple smaller polygons
4564
10-25-2018 03:41 PM
IsabellaBeharrell
Is there a tool to create one large polygon feature using a existing polygon boundaries? The attributes from the existing polygons are irrelevant - just need the outer boundaries (do not account for features within the polygon cluster) to create one large polygon. Any suggestions?
DanPatterson_Retired
If you convert the polygons to points, you might be able to create a concave hull from the shape
https://www.arcgis.com/home/item.html?id=8f41ef2ee8f3400689490de520707c58
otherwise a convex hull will be probably as good
Minimum Bounding Geometry—Data Management toolbox | ArcGIS Desktop
MarkBockenhauer
Isabella,
You could try Snap
For example, I have some polygons.
Create or use another polygon that is fairly dense with vertices that encompasses these polygons.
Then use Snap
Click run
Experiment with the distance to get the desired amount of snapping.
mark
MathieuBoonen
Dissolve is another method to generate one large polygon if you just want the features  It needs one common attribute to ensure a single polygon is created and IF  they are all touching one another, otherwise you will end up with a multipart polygon.
Dissolve (on Attribute)
Alternatively Aggregate Polygons is another Tool which does a nice job from a cartographic sense.
Aggregate Polygons
