Can't Change background color of form
2732
10-25-2018 06:34 AM
joerodmey
I’ve been trying to change the background color of my survey and can’t seem to accomplish this.
My setup:
  • Created survey with connect
  • Using survey as a web form only
  • Want to change green background color behind the form, not the form color
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
Please refer to https://community.esri.com/thread/218865-viewing-survey123-form-on-web-pale-blue-wrapper .  Note that this will change slightly in 3.1 as the web designer will expand the theme capabilities; surveys published in 3.0 will not be affected if version locking is on (which it is by default).
JamesTedrick
Hi Joe,
joerodmey
Thanks for the help. Worked perfectly
