Excel cell value as variable?
2627
8
10-23-2018 02:33 PM
by Anonymous User
Not applicable
I'm trying to pull cell values from the files I'm grabbing in the code below so I can write them in the loop for a new column. The column will be called ADT and their value is in cell A333.
import os, sys, pandas as pd
path = r"C:\Users\anthonyv\Downloads\Metro\New folder"
files = os.listdir(path)
data = []  # a list to hold your data
for filename in files:
    f = filename.split(' MP ')
    address = f[0]
    mile = '.'.join(f[1].split(' ')[0].split('_')) # convert underscore to period
    df = pd.DataFrame({'MP': ["{}".format(mile)],'RdNm': ["{}".format(address)]})
    data.append([address, mile])
df = pd.DataFrame(data,columns=['Road','Milepost'],dtype=float)
writer = pd.ExcelWriter('MetroReportAGOL.xlsx')
df.to_excel(writer, sheet_name='Sheet1')
writer.save()
print ("Complete")
DarrenWiens2
You do a bunch of work to get things into the dataframe within the loop, but never use it. Rather, you append to 'data' (2 columns), and then attempt to make a new dataframe from that (specifying 3 columns).
I assume you should use:
data.append([adt, address, mile])
DanPatterson_Retired
what does it do now?
by Anonymous User
Not applicable
It's pulling values from the filename and adding it to an excel table. I'm now wanting to pull cell data from within each file and add it to the excel table it is creating.
DarrenWiens2
You first need to read the file into a dataframe:
excel = pd.read_excel('path/to/xlsx')
Then, find the value:
excel.iloc[row_index][column_name]
by Anonymous User
Not applicable
I made the change mentioned above and am receiving the error below.
DarrenWiens2
by Anonymous User
Not applicable
Thanks for you help!
JoshuaBixby
MVP Esteemed Contributor
As an FYI, the issues you are running into have nothing to do with ArcGIS, ArcPy, or any other Esri product.  Doing some online searching, especially in places like StackExchange/Overflow, will likely provide suggestions to users who are having similar issues as you are here.  I am not discouraging you from posting on GeoNet, I just want to point out there are many other avenues to troubleshoot your problem once it has nothing to do with Esri.
by Anonymous User
Not applicable
The final table that's created from this script will be updating an ArcOnline feature service. Thanks
