Editing existing survey data
606
10-18-2018 01:41 PM
JevaughnHenry
I am trying to edit existing data inputted into a survey. However, I am seeing the popup message "Accessing data failed" when trying to the edit the data through the map viewer of ArcGIS Online.
I am unable to edit the records in the Data tab of the hosted feature layer in ArcGIS Online (N.B. all settings have been configured to allow editing of data).
I am also unable to edit the records through the the Open in Map Viewer tab on the Survey123 website. As soon as I make an edit to the records, the changes disappear and are not able to be saved.
Any assistance would be much appreciated
JamesTedrick
Esri Esteemed Contributor
Hi Jevaughn,
Just to check, are you editing the feature service or the _stakeholder view (which is created when a survey is shared for viewing)?  The latter has editing disabled by default to provide a read only access point to the data.
JevaughnHenry
Hey James,
I am editing the feature service.
