Spatial join for several features with a for loop
3845
10-18-2018 01:42 PM
SilvanaCastillo
I'm trying to do a spatial join between sevaral feature classes as join features and one feature class as the target feature. I have written a python script for this but I get an error when I execute it.
import arcpy
arcpy.CheckExtension('Spatial')
arcpy.CheckOutExtension('Spatial')
arcpy.env.workspace = 'C:\Lab_5\Lab_5\AAB_gdb\AAB.gdb'
#This is to check if these are the feature classes that I want to use
defor_years = arcpy.ListFeatureClasses("def*")
for i in defor_years:
print i
#This is to create the output name for each spatial join
output = 'C:\Lab_5\Lab_5\scratch_gdb\scratch.gdb\spatialjoin_'
for i in range(0,len(defor_years)):
   year = defor_years
   name = output + str(year)
   print name
join_features = name
#Setting the variable for the target features
target_features = 'C:\Lab_5\Lab_5\AAB_gdb\AAB.gdb\commune'
arcpy.SpatialJoin_analysis(target_features, join_features)
When I execute it, I get this.
I guess it's not taking each output of the for loop, making that the final spatial join failed. Can anybody help me with this? Thank youuu!!!!.
SilvanaCastillo
Here's the answer for anyone if they ever have to do something similar:
#Import arcpy module
import arcpy
#Checking if Spatial Analysis Extension is available
#Taking Spatial Analysis to work with it
#Setting the environment workspace
#List of the files we are going to work with
  print i
# Setting the output for the new files
output = 'C:\Lab_5\Lab_5\scratch_gdb\scratch.gdb\spatjoin'
# Setting target features
# Creating a for loop to iterate over files
    year = defor_years[i]
# Since there are going to be several files as output,it's necessary to create a different name for each
# Prints te name of the new files or outputs
    print "name =" + name
# Executing the spatial join using as join features the files that were been iterated
# and as output_feature class the name established above for each new file
#The option KEEP COMMON maintains only the records that were common between the target
# and join features
    arcpy.SpatialJoin_analysis(target_features, year ,name,'','KEEP_COMMON')‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoeBorgione
You need to use the syntax highlighter to post code; no one can tell where your for loops end since the indentations are omitted.
Look at what the error is telling you. It may stem from you not properly seting your workspace.  I suggest using:
arcpy.env.workspace = r'C:\path\to\your.gdb'
Otherwis you need to escape each of the back slashes with a back slash:
arcpy.env.workspace = 'C:\\path\\to\\your.gdb'
SilvanaCastillo
Thank you for your suggestions. I already change what you said but it didn't work.
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
Spatial Join—Help | ArcGIS Desktop
spatial join requires two 'layers', so if you aren't running the code in the interactive window or have *.lyr (*.lyrx) files,
it won't work.
you will have to make feature layers before you do the spatial join.
Make Feature Layer—Data Management toolbox | ArcGIS Desktop
SilvanaCastillo
import arcpy
  print i
# and join features
