How do I get question names using the REST API?
1458
10-18-2018 08:55 AM
MattStayner
I would like to get the question names for a Survey123 form using the REST API. What is the best way to do that?
I found the following endpoint, which gets me close:
https://www.arcgis.com/sharing/rest/content/items/[item_number]/info/[form_name].webform
In the return object from the above endpoint I get a key-value pair where the key is "model" and the "value" is shown below. It looks like XML, but there is a "\n" on every line that is making it difficult for us to process.
<Form_3
xmlns:esri=\"http://esri.com/xforms\"
xmlns:jr=\"http://openrosa.org/javarosa\"
xmlns:odk=\"http://www.opendatakit.org/xforms\"
xmlns:orx=\"http://openrosa.org/xforms\" id=\"Form_3\">\n
<starttime/>\n
<AOMInitials/>\n
<AOMOther/>\n
<DailyScheduled/>\n
<SpecialInspectionType/>\n
<SpecialOther/>\n
<SpecialLocation/>\n
<endtime/>\n
<meta>\n
<instanceID/>\n
</meta>\n
</Form_3>\n‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
How can we convert that to standard XML/JSON? Is there a better endpoint we could use where we could get back the "model" in JSON or correctly formatted JSON?
Thanks!
Matt
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Matt,
The webform uses an XForm XML file that has been embedded within a JSON file.  To get the field names directly, there are a couple of methods:
1) Scan the Feature Service Layer's REST endpoint.  The fields are present and, if published by Survey123, will have the labels of the questions set as field aliases.
2) Access the [form name].xml info resource (as opposed to the [form name].webform) - you will see this in the file folder of a survey in either Survey123 field app or Survey123 Connect.
JamesTedrick
Hi Matt,
MattStayner
James,
Perfect! We opted for option 2 where we can hit the endpoint sharing/rest/content/items/SurveyID/info/[name].xml
I knew the XML file existed in the folder on my laptop. I didn't realize that endpoint existed. That makes it way easy to access the form definition. Thanks!
