Proper ESRI format for a JSON file
4409
5
10-17-2018 12:57 PM
JustinBridwell2
I keep getting a 001558: Error parsing .json file. According to ESRI documentation for that error, "the JSON must have at least the geometryType, spatialReference, fields, and features (with geometry and attributes) property."
I checked my .json file and it appeared to have all that but I want to see an example of a proper format. Can anyone give me a proper example of hwo ESRI want a file to look. Below is what my .json file looks like:
{"displayFieldName": "CSLF_ID","fieldAliases": {...},"geometryType": "esriGeometryPolygon","spatialReference": {  "wkid": 102100,  "latestWkid": 3857},"fields": [...],"features": [  {"attributes": {...},   "geometry": {...}  },...]}
JoshuaBixby
MVP Esteemed Contributor
What tool is generating the error and how are you calling it?
JustinBridwell2
I've tried this in both my Python script using:
arcpy.env.workspace = directory + "/gdb"
path = "<filepath for json file>"
fc = arcpy.JSONToFeatures_conversion(path, os.path.join("cslf.gdb", "cslf_{}".format(today)))
As well as using the manual JSONToFeatures tool in my toolbox in ArcMap (under Conversions) just using the same file. Both give me the exact same error.
JoshuaBixby
I think An overview of the JSON toolset—Help | ArcGIS for Desktop is out of date.  I thought "fieldAliases" was deprecated back around 10.0.  Try removing that element and see if it works.
FeatureSet object—Common Data Types | ArcGIS for Developers
JustinBridwell2
The only difference that I can see in my JSON data is that the geometry comes after the attributes in features. But this was working up until yesterday.
JoshuaBixby
If it was working up until yesterday, then I am at a loss for why is stopped working.  Did you install any new Esri software, patches, or updates?  Have you tried rebooting the machine?
