How do you create a new label class?
1484
5
10-18-2018 07:16 AM
MichaelStranovsky
I would like to be able to create a new label class on a featurelayer using the sdk.
UmaHarano
Here is a code snippet to create a new label class and assign it to a feature layer.
Uma
QueuedTask.Run(() => {
                var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First();
                //get the layer's defintion
                var lyrDefn = lyr.GetDefinition() as CIMFeatureLayer;
                //Text symbol to use for labelling
                var textSymbol = SymbolFactory.Instance.ConstructTextSymbol();
                //Create the new label class and initialize props
                var newLabelClass = new CIMLabelClass
                    //Define the label expression engine
                    ExpressionEngine = LabelExpressionEngine.Arcade,
                    //Expression to use to label
                    Expression = "$feature.NAME + $feature.Shape_Area",
                    Visibility = true,
                    TextSymbol = textSymbol.MakeSymbolReference(),
                    Name = "MyNewLabelClass"
                //Most of the Maplex and standard engine placement properties get set automatically.
                //But you have to set the feature type explicitly. Line seems default.
                var maplexLabelPlacementProps = new CIMMaplexLabelPlacementProperties
                    FeatureType = LabelFeatureType.Polygon
                var standardLabelPlacementProps = new CIMStandardLabelPlacementProperties
                //Set the placement prop defined to the label class.
                newLabelClass.MaplexLabelPlacementProperties = maplexLabelPlacementProps;
                newLabelClass.StandardLabelPlacementProperties = standardLabelPlacementProps;
                //Get the layer's label classes
                var lyrsLabelsClasses = lyrDefn.LabelClasses.ToList();
                //Add the new label class to the labels label class
                lyrsLabelsClasses.Add(newLabelClass);
                lyrDefn.LabelClasses = lyrsLabelsClasses.ToArray(); //Set the labelClasses back
                lyr.SetDefinition(lyrDefn); //set the layer's definition;
MichaelStranovsky
I tried it and it did not work. It does not create the label class and assign it on any of the layers.
MichaelStranovsky
Never mind , I was able to get it to work.
Thank you
MichaelStranovsky
Hi Uma,
Is there a way to get at the following:
To enable them through the sdk?
Thank you Michael
MichaelStranovsky
I actually figured it out….AutoReorder on the CIMLegend
Thank you
